Energy Suspension HYPER-FLEX SYSTEM Complete Master Bushing Set
Hey everyone, I am doing a full overhaul on my suspension. So far I have a set of Omni-power Coilovers, Ingalls front camber kit, and am using the bolt/washer trick for the rear.
Now I just need to pick up new bushings, what are ppls opinions on this kit, good buy or good grief. Know of a better one? And any suggestions on where to pick it up? Thanks for taking the time to read this. Late.
PS- Did search and found some info but was hoping for more ideas/options.
I think its worth the money I love the way the suspension feels on my car I have TEIN S-Tech springs with KYB AGX in the front and Tokicko blues in the rear If I bought another G2teg I would def buy the kit and get it installed
made a huge differents in my ride. i also changed the control arm bushings w/ ES black ones(some say go mugen/OEM) and i changed the radius rod bushing too.
are you going to change them yourself?
I’m happy with mine. I also changed other stuff at the same time (mugen trailing arm bushings, new tie rod ends, and new alignment settings) so its hard to say for sure how much of an effect they had. I’d say they are worth it though, they’re pretty cheap compared to your other options for replacing all your bushings.
If you’re planning on redoing all your suspension I would HIGHLY suggest you get new trailing arm bushings too. In fact I would say this should be a priority. They should have more of an effect than the ES kit.
