Engine filled with water!
Drove my car into a lake (on accident), well it wasn’t really a lake just a large puddle, but my engine hydro-locked. I pulled the plugs, and got it all cleaned up. The engine runs, but there’s alot of noise coming from the motor. It sounds like every rod is knocking. How could I have bent every one when there was only one in compression mode? Could the fuel injectors be screwed up? Could it be anything else? I pulled the plug wires one at a time to see if the clattering would quiet down and it didn’t. Is my motor junk now?
Probably, if your engine was filled with water, and there is a lot of knocking coming from the motor, I would guess its fooked. How did you get it all out?
puddled pwn3d jo0… :sad:
