its no different from swapping in any other b series vtec engine—they all bolt in, the only things that are different between diff engines will be the ecu you will need (and in some cases the intake manifold you will need).
go to the teg tips, download the vtec swap guide, read it over and over and over and over again until its in your memory for good.
