Engine misfires and smells of gas out exhaust.
A few days ago I was sitting at a light and noticed my car would misfire every so often, but still ran good.
Well, I got home after a 100 mile drive last night and when I went back out to the car and started it, it started ok, then immediatly started misfiring. Also there is the smell of raw fuel coming out the exhaust.
I started it cold today and it sputtered when starting, but smoothed out when it went to 1500 rpm. When it went down however it started misfiring again and smelling like raw fuel out the exhaust.
It misfires at all rpm and the raw gas smell is ever present.
I need to know if anyone else on the board has had this problem and what the most likely fix is. I am poor and cannot afford to replace everything till it is fixed.
b18a1 with an automatic transmission. 214000 miles, new fuel filter, air filter, adjusted FITV, cleaned IACV.
Just checked 4 spark and all 4 wires are delivering ignition.
When I pulled each one it would make the car stall, except the 2nd one which made no differience. It was getting spark, too. (you could see the wire sparking against the head when the wire was pulled.)
Check timing.
paul, when you pulled 3 and 4 did the car die? Also, if you slightly held the spark plug wire above the spark would it make the car idle better? I have this problem just seeing if you have the same problem.
[QUOTE=paul06660;2087297]Just checked 4 spark and all 4 wires are delivering ignition.
When I pulled each one it would make the car stall, except the 2nd one which made no differience. It was getting spark, too. (you could see the wire sparking against the head when the wire was pulled.)[/QUOTE]
You pulled the #2 cylinder spark plug wire off of the plug and it made no difference? You could have an injector that has gone bad or a dead hole. I would swap the injector with another hole and see if your problem moves to a different cylinder. If it doesnt move check compression across your cylinders and you will probably find a serious loss of compression on your second cylinder.
J
could be many things. usually when the car misfires real bad and smells a lot like gas its the ignition timing. however it can be a cylinder not firing also such as a bad injector, no spark to that cylinder, spark plug, etc.
Well, for some reason the car was not igniting the fuel in #3. ( the second cylinder on the distributor side). The plug was a little loose but tightening it allowed it to burn the gas again. However it still runs like shit. I am left wondering if I have a valve sticking. It starts rough cold but smooths out when the FITV kicks in. When it even begins to warm up it starts running like shit.
Sometimes when driving it cold it will go back and forth from running good and then like shit. I am getting no codes and I am positive the distributor, and EGR is ok. I am pretty sure the timing is ok because it does go back and forth from running good.
from that last post sounds like maybe the FITV isnt working right or is sticking. you say as the FITV comes into play it works fine but then and full op temp it goes to crappy again
same here
My car does the same thing. it misses a lot even though its a new distributor. it very hessitates in low rpms, like when i take off at a stoplight i really have to give it gas because it will hesitate and even stall if i dont.
I heard it could be the fuel filter\pump. it used to throw code 43 but i replaced almost all of the ignition and now it doesnt, but still misses and failes SMOG.
I did check the orifices in the throttle body for the IACV and FITV. The FITV was Completely closed (no air flow) when warm. The IACV was allowing the air to flow like it should of.
Now if I remember right, isnt the FITV supposed to allow a little air to flow thru the orifice when completely closed? I have adjusted it before because of bouncy cold idle, It did fix it but lately it seemed like it might of needed adjusted again with fall setting in.
Ill take it off and adjust it again tomorrow. However I feel like it wont fix it.
Nope, not the FITV.
ive been having the same prob for the past 2 days. i take out the spark plug wire from cynlider #2 and the car stays the same. but i take the other 3 wires and the car trys to die
I am pretty sure one or more of my valves are sticking in the head. I am throwing no codes, all systems seem fine.
Earlier this summer the car would occaionally smoke when starting (blue). It would only do it when starting every now and then, but that was probablly a sign of valve seals getting worn out.
Well as it stands I could swap a rebuilt head but in the long run I think it is better just to swap the block with a JDM b18b. The transmission is still good, and I need the car to last another year so I can save for an RSX.
I have found a 30,000 mile JDM b18b for $600. How much should I expect to pay to have the engine long block swapped? I have an automatic.
Can the block be removed without pulling the transmission?
could a bad O2 sensor cause this and not set off a CEL?
Engine runs ok till it warms up.
no when the engine is cold it runs in open loop and doesnt take the reading from the o2 sensor until it reaches a certain temp and goes into closed loop.
I have narrowed it down to the possibility of a bad cap and rotor.
Since I have had the car it has always made a rattle in the distributor cap. Lately I have not heard that rattle. So I took the cap off yesterday to find that there was some brown buildup on the contact points and the rotor metal thingy.
The contact points in the cap look pretty worn. Possibly from rubbing all the time. So I took the cap and rotor and scraped some of the brown corrosion off.
I was going to replace the cap and rotor, however the rotor does not want to come off.
Well, after putting the cap back on and running the car, the car does run a LITTLE better. It dosent misfire as much and when it is running good there is no smell of gas out the exhaust.
well Paul, this one problem seems to be a reoccuring thing in our community, I posted about two weeks back, new distributer, plugs, wires, fuel filter, pump, main relay, u name it. If the car has over 150,000 miles, i’ve found out 70% of the time its due to a sticking valve, even if u maintenence the car regularly, Seafoam is my new best friend. and will let u know if u have a sticking valve. Just follow the instructions on one of the threads here, get that carbon removed from your intake valves, and this might help u troubleshoot a little bit better. It worked for me.
Help!
Hey so I got a new cap for my fairly new distributor, since the old one was pretty loose and missed a lot, and after tightening the little screw it still has a tiny little play in it. is that normal or is my distributor bad? thanks guys!
Well, today I swapped out the cap and rotor on the distributor and it made little if no differience at all.
The car will stay running good for a while till it warms up. But even when it is warmed up it wont always misfire. If I Idle it in park it will hardly misfire at all unless I punch the gas to rev the engine. Then it sputters at first and revs like it should.
Most misfiring and running rough occur when I am idling at a stop and when I take off. The engine will run like crap until it decides on its own to stop misfiring (usually around 2,000 rpm) and run like it should. Also when driving down the road and holding steady speed, if I give it some gas to go faster it will misfire and not want to go faster. Again backing off the gas usually gets it to run properly.
What is the most likely culprit here?
Delete this post
