ps-when the timing belt breaks, and yo would find this by searching, you stand a chance of really fucking up your engine. the pistons have a chance to slam into the valves, since the belt is no longer leading them. if enough inertia is present at the break, the engine will sorta destroy itself, so to speak. you need to probably do a compression test to see if your valves are OK and sealing properly. hopefully, just a bad positioning of the cam gears. good luck.
