Hi guys,
I have a 1991 rs 4 door auto. I had a little trouble starting the other day, the engine would start but soon as I let go of the key the engine stopped, I figured it was just because it was freezing outside, as I’ve had it happen before in freezing temps. So I give it some gas as I start it and everything is fine.
Today after work, I started the car and let it idle to warm up. so about 10 mins pass, I come back to the car to pull out. Soon as I put it into reverse, the engine shuts off. Then tonight when I went to start the car everything seems normal, the engine is turning, soon as I let the key go, the engine stops. I start trying to get it going, giving it gas at the same time im turning the key, and finally I get it runnning (after like 7 tries). I can see the RPM’s go up, but it just dies (when trying to start it)
I stop off at a friends, and its in the back of my mind constantly, I keep thinking something is wrong. I fear it wont start when I leave, but it starts like normal 1st try. Soon as I put it in reverse the engine stops. THen when I try to start it, same problems as before (having to give it gas, bout 5 times I tried). Engine just keeps turning off as soon as I get it into reverse. I had to put it in neutral, start it, let it coast off the driveway and drive home. AFter driving I get home and stop. I put it into reverse, everything is fine. ALso the temperature today is not cold (least by our standards maybe only negative 2 celcius)
I did have the o2 sensor and the fuel filter changed about 2 months ago (us thanksgiving weekend) ago, but there was no problems till now.
Does anyone have any idea what could be causing this? Its only in reverse it shuts off, or in park I have problems with it starting.
A secondary question here
I also have a second problem. Around 3 months ago, I got in my car, and I hear a weird hissing, like pressure escaping from somewhere. I didnt see anything, or smell anything. Since then my gas has gone down from roughly 375 to 400 km a tank, to 300 if im lucky. Any ideas what could cause this? Keeping in mind I already changed the fuel filter and o2 Sensor.
Any help is much much much appreciated. And yes I did searches
