In that case, check the power lead from the starter relay to the S-terminal on the starter.
You may also want to check the brushes and plunger inside the starter for wear.
Will do. Achon- is it true that theres no ground attaching to the starter? Does anyone have pictures of this.
yes, it’s true that there is no ground cable directly attached to the starter. It uses the grounds that attach to the engine. One of which is the one that goes from the battery negative -> chassis -> transmission.
