Alright I just got done swaping a b16a into my 90 Integra. I hooked everything up and double checked it. but when i went to start the car it wouldnt click over like if it was gettin no spark. It makes this noise like thump cant explain very well.
The only things i did notice was in the fuse box (engine) it was missing a clip which is alb and is supose to run to harness.
Could that be the problem?
if it doesn’t click over have you check the ignitor, distributor, firing order, starter?
are all grounds grounded correctly?
check ur distributor.our obd0 distributor suck ass.i had a problem with mine after my jdm swap.
