[QUOTE=welfare;2277278]probably rent one for cheap enough. i probably wouldn’t go buy one[/QUOTE]Nope, no part store in MKE has a loaner.
In any case, I decided to do the timing belt first, then set the engine to the spec’ed 16 degree advance, then the rest of the regular tuneup stuff. I had a friend check the vacuum, & there is no evidence of a leak @ idle or fast idle atm.
Since the crank pulley was off, I recreated the timing marks with white touchup paint and some nail polish, so I should be good to go there. B/f I took it off, I checked the pulley for TDC, and it was not even close, so the old belt must have skipped a tooth or two.
Btw, the tool I used to keep the crank pulley in place was a “50-mm Crank Pulley Holder for Honda” by Powerbuilt, p/n 648796, $13 from Amazon. Of anyone else is interested, I can post pictures… may be good for some other newbie.
Had some trouble getting decent tension on the tensioner pulley even after taking the spring out to make sure it was ok, and backing out the tensioner pulley bolt quite a bit, but all seems ok now and lined up. (Using a Dayco timing belt). Car starts &idles ok, at least.
Flange nut on the lower alternator bolt did not come quietly, and will have to be replaced (loosening the upper adjustment bolt was not enuf to release the alternator to swing on the lower one in its track).
The real trouble started when I replaced the motor mount though. For some reason, getting it lined up using a jack and a board under the oilpan took three tries, and, to add some discontent to my winter, the lower bolt now has one flattened thread in the middle, and will NOT go back in. Everything else lines up, the other two bolts are torqued to spec, a different fine pitch bolt threads in from the top and the holes look lined up, but the bolt that came out will only go part way in from the bottom :mad:
Anyway, the engine still starts and runs after all this silliness, at least @ idle.
