hey, im interested in buying an nrg engine damper and im wondering if anyone on here has one installed. do they work good? any feed back would be great thanks.
woops, is there a way i can change the title? i meant engine torque damper
Engine damper
nrg makes engine dampers. just wondering if anyone has one currently. does it work well?
It’s not a bolt on part, right? I have never seen an engine damper for the DA, with the exception of a friend’s car (custom made).
yea i find them all the time. it would be easy to make a custom bracket but it would have to be strong. http://redline9.com/i-286534.aspx
i personaly havent seen a da with one. im trying to get more info that way i dont go out and buy one only to find out it wont even fit.
Yeah, that’s not application specific at all if it supposedly fits all of those vehicles. It might be “bolt on” for some, but not the DA. None of the dampers which are “bolt on” for other chassis work on a DA w/o modification - as far as I know.
If you’ve got the tools and fab common sense then yeah, it wouldn’t be hard to make at all.
