The engine won’t turn over-i’m going to have a new head gasket installed because my engine was running on low compression(leak). Now my car is at my friends house because it won’t start. My friend’s uncle said the spark plug wires weren’t getting any spark-my friend and i checked the distributor and it wasn’t getting any spark either. His uncle said it was probably a blown fuse-my friend and i couldn’t find it.
Does anyone know where this fuse might be?
DOES THE ENGINE CRANK AT ALL? IF SO AND YOU AINT GETTING ANY SPARK TRY REPLACING YOUR COIL. I JUST DID MINE.
Yeah, i can hear the starter motor. What would cause the coil to go bad(besides a leaking head gasket w/ coolant inside the sparkplug bay)? it started when i pulled out the drive way and like 2 mins later i tried to start it and it just didn’t turn over.
