Does anyone know why my 1.6l dohc non v-tec in a 90 teg rs kinda doesn’t wanna go when its warm, I start it up and the rev’s are just like normal and the car will act like normal, Once it is warmed up It will resist acceleration, seems as if it missfires but it doesn’t, I replaced my distributor cap and spark plugs and spark plug wires, I am getting an engine swap to a 1.6 L v-tec but I was just wondering what this could be, I was thinking along the lines of either the fuel rail or the fuel pump… Thanks
when you replaced your distributor cap, did you also replace the rotor with original parts? are the plugs gapped according to specs? also, i really doubt you have a problem with the fuel rail, but you may want to check up on your fuel filter if replacing the rotor doesn’t solve your problem…
They made a 1.6 Liter 2nd Gen integra in canada? weird.
are you sure that it is a 1.6 liter? that engine was in the 1st gen integras
I thought that cheap japanese DA6’s had zc’s?
