Like my title says it dies as soon as I turn it over. Happens when cold, happens when warm… is very intermittent & worse in the morning when I start it for the first time. it will continue to do this until I give it gas. If I tap the gas pedal while turning it over it starts up just fine and stays running.
once the motor is running it runs fine. Check the video below to see what I am talking about.
hard to tell in the vid, but is it shutting off right when you drop the key back to run? also noticed that, for most of the video, when it dies, the instrument cluster lights aren’t coming on. another telltale sign of a failing ign switch. if those assumptions are accurate
absolutely suspect the ign switch then. the contacts are probably dirty or the solder joint is cracked. when you throttle, the voltage increases which overcomes the level of resistance caused by the bad connection. that would be my theory anyway
[QUOTE=unified112;2277315]Hey, that was my second guess!
haha. you got it, bud.
dj, you can also try cleaning the contacts of the switch with some emery cloth. or if any of the solder joints are cracked, you can just reflow the solder. it’s almost always one of those two issues
I didn’t dig into the steering column too deeply yesterday, but it looks like only a couple screws (well 1 i my case as the other is missing) to remove the housing, and 2 screws holding the switch to the key cylinder.
is it tricky to remove the ingition cylinder to get at the switch at all? Haven’t had to do this but a quick glance it looked relatively simple to do?. Worst case I’ll go read through my CHilton manual and see what it has to say about it.
