Has anyone made custom rails or installed any in a DA??
:rules::search:
i search several times and i havent found anything
i bought weapon r seat brackets, cut off the stock ep3 mounting points and welded the weapon r bracket to it.
looks like this…
got some rsx seats that im bout to put in now
can you take some close up pics of the rails???
anyone else know
seats were sold already, its not hard to do…
buy these
http://www.racinglab.com/ac90inwerase.html
cut off the old ones and weld these to do
got it im gunna try it thanks man
924dr - did you also swap in the EP3 rear seats as well? Can’t really tell if thise are DA or EP3’s… if they are EP3’s, are they a direct fit… thanks!
A member on here did a write up on swapping those front seats a while back. Not sure if the thread is still available.
^^ yeah but it looked like he swapped the rear seats in as well. Just curious if it was a direct fit?
the back seat is jdm itr, i had to cut and weld all new brackets for the seats to fit in, it look good but once you do this you cant go back to the stocks anymore
would the seats sit high in the DA?..my friend had EP seats in his DC and they would sit high. the top of my head would be like 2in away from the roof…
