Erratic RPM's while driving
Ok car runs purrrrrfect at idle. However once I start driving down the road the RPMs start jumping all over the place and the car eventually dies. 93 teg stock LS and its throwing a code 16 (injector). Any suggestions?
i would have to say it could be fuel related if its injectors. If its a code 16 after many trials i it has to be a clogged injector or bad one?
Can be fuel pump worn or not putting out enough or something clogged. Fuel filter? Also i figure since its at idle and its fine perhaps the sensors from injector/ecu is tripping the code 16 due to not enough pressure when you driving higher rpm? i cant explain it right but sounds like it to me.
