ES radius rod bushings
Hello people.i bought new ES strut rod(radius rod) bushings and i dont know how to
properly install them.here are pics of 2 posible position.wich picture is rigt?
2-
and also do i need to use this metal part from OEM bushings?
thank you for answers
bump i wanna know too haha. i got the ES insert for the motor mounts its pretty good. n if i was to guess it goes in like this. this in the back < and this in the front > nad im pretty sure you still have to use the metal piece.
Here is what the service manual has for OEM radius rod bushings:
As for the metal sleeve, perhaps someone else can chime in. Alternatively, you could check Energy Suspension’s website. From what I remember they have quite a bit of info for their bushing kits on there.
search bar…
http://forums.g2ic.com/showthread.php?207289-vertical-bar-ES-bushings-issue&highlight=
Yes you need the metal part from OEM bushings.
