The B-pipe on my DC catback is rattling bad. Will I run into any problems and differences if I cut it out and slap a piece of piping in its place.
thanks
thanks
check your heat sheilds
its not the heatshield I took the mid pipe right off and there is something inside the B-pipe sounds like dirt or somthing. I tried to pressure blast it but no good its right inside.
Any help would be appreciated
Most likely your resonator insides are deteriorated and are flying around in your resonator if it’s in fact coming from your B-pipe. Have a competent mufler shop cut out your old resonator and weld on a new one.
I agree with Ive, or else it could be your cat falling apart.
Can you recommend any competant muffler places in the 604 area
Lower mainland
Thanks for the input
