f1 clutch
has anyone used a f1 clutch
i got one… 6 puk stage 3 and it grabs to hard so i would go with the full face stage 2 with a 8lbs flywheel but over all i like this clutch and flywheel set up.
poop. they are cheap for a reason. after break in it blew up and f’d over a fidanza aluminum flywheel real good. i would highly suggest going with a better brand
[QUOTE=BBP-GS DA;1718894]poop. they are cheap for a reason. after break in it blew up and f’d over a fidanza aluminum flywheel real good. i would highly suggest going with a better brand[/QUOTE] whjat made it break do u know.
[QUOTE=JDM_DA9;1718849]i got one… 6 puk stage 3 and it grabs to hard so i would go with the full face stage 2 with a 8lbs flywheel but over all i like this clutch and flywheel set up.[/QUOTE] ok thanks
not sure but my guess is the clutch isn’t made to handle much power. or possibly just a cheap clutch. it was a 6puck. i ran it on a boosted b17 and it blew up within a month. the rivets let go and things went flying. i would suggest to look at something better. i personally went with an act this time.
I have a 6 puck XTD and it grabs like crazy. Also the pedal is as soft as stock. Ive heard it is basically an ACT clutch with less “meat” but Id recomend them. I also got it paired with a 10lb flywheel.
