factory steering wheel
On the 92 and 93 tegs there’s a center piece on the steering wheel that hides the bolt to take off the steering wheel right? Mine always comes off when I’m driving and its sooo annoying! Are there any quick fixes for this?
y2ken@telus.net
Use a little bit blob of silicone around the edges of the cover and it should be fine as the silicone is fairly easy to pull off.
what type of silcone should I use?
Try 3M, double-sided tape. Holds great and not at all messy!
Did it freak you out the first time? I think I was racing a friend, and as soon as I left first gear it flew into my lap.
Yeah the first time it scared the crap out of me…! I’m kinda used to it now tho…! So whats going to work better…double sided tape or silcone?
3 dabs of goop. It won’t take much to hold it. The tape will get messy from the heat after a while, if you ever take it off again. Goop will stink for a bit but will hold. it is elasticky once dry and removes easily.
three dabs of what kinda silicone? There’s like different types and I don’t know what kinda to use?
I used roof and gutter silicone the clear stuff but any type should do and all you need is just a little bit and it will hold on good
Goop. Go to Canadian Tire and you’ll find it. In a squeezable tube.
There’s different kinds, just get the automotive one.
