Failed smog TWICE! Need help ASAP!
[QUOTE=hybrid90;2146500]Funny you said I ran too much HEET. Someone on HT said if you run too much… you will cause a lean condition and thus not making the car operate at normal temp so you will fail… who knows…
The tech said my O2 isn’t working/reading cuz it didn’t register any numbers on the printout… it was at 0. But I think you’re right, if it wasn’t working… I would have a CEL. Maybe the engine wasn’t warm enough for the O2 to sniff anything?
Welfare - haven’t gotten around to scanning it cuz the paperwork is in the Integra which I don’t drive much… I’ll try to post it up asap when I remember.
Thanks for all the input so far guys…[/QUOTE]
smog machine does not tap into your O2 or any sensors if u have a DA 90-93
which is why i don’t understand why he says your o2 is not registering
it was probably the heet. cuz it sounds like you’re running lean.
