Fan Never Stops!!
I NEED SOME HELP. I RECENTLY SWAPPED AN ENGINE IN AND THE FAN NEVER STOPS RUNNING. I FINALLY JUST UNPLUGGED THE FAN. THE CAR RUNS FINE THOUGH IT NEVER OVER HEATS. I THINK THE RELAY MIGHT BE BURNED OUT BUT I AM NOT SURE.
Use your inside voice.
Why dont you just hook up a cool looking switch to the fan power line and un the fan when its hot or when you shut your car off when you know you are just going to be gettin back in it.
.02
Check your fan ralay…
Just follow the wires and you will find a little black box…do you have a manual?
-Jeff C.
Stick your finger in it. LOL just kidding, check your relays and everything that runs back to the black box!
CHECK THE RELAY OR CAN DO THE SAME THING I DID WIRE THE FAN INTO THE IGNITION OR USE A SWITH. YOU WILL GO THROW FANS BUT IT HELPS…:gun: :gun: :gun:
everyone stop shouting!
