Just yesterday I noticed that when I turn on my left blinker it blinks at least twice as fast as it used to. I also noticed that the front left signal light is not working.
Is this a fuse or light problem? Thoughts? I’d like to get some insight before I buy a new bulb and take off the lens, etc. Thanks!
It means your bulb is burned out. Simple as that. It blinks twice as fast because there is less load on the flasher circuit and thus releases it’s coil surplus engergy faster (if you want a somewhat technical explanation).
Sometimes corrosion between the bulb and contact prongs prevents a good conduction so double check to make sure that the bulb harness contacts haven’t rusted and if so, simply sand them down a bit till you see shiny metal again.
