well after a lot of reading i think my icu maybe faulty and need repaired replaced.
90 rs w/ 98 p8r head b20b ls manual trans all components are obd0 265k on chassis 70-80k on b20b
symptoms:
- oil light slowly goes from off to brightly lit longer you drive.
- it also flashes with the left turnsignal indicator when its activated in cluster. its been doing this for a good 2 months now.
- oil light started flashing the other night on me i had no option but to drive it home 2 hours of 55mph average speed.
- oil level and appearance are good.
no ticks knocks pings head is getting oil.
- it is 2k or more overdue for oil change though
i have checked the yellow/red colored pressure sensor wire lead from the connector to the plug on the engine side of harness.
aside from the plug not being oem and about 2 inches of wire behind plug being stiff or brittle feeling ( it feels like the copper wire is severely oxidized or has been overheated at some point.
** side note here : the oil light does its dim to bright behavior and the blinking when i accidentally had it connected to the now unused black wire ground lead for the old ect switch
it behaved the same when conected to the yellow/red wire as well
i did take the y/r wire for the pressure sensor and directly powered it off the pos+ bat terminal.
with the key off the light was bright solid lit up
turned key to on position and it completely turned off
- rear defroster doesnt work tried multiple defroster switches no light up no operation
- seatbelts sliding action started being intermittent with operating properly just the drivers side but pass side n drivers side operate differently. currently unplugged from pass side kik panel modulem
- wiper selector might be starting to act up uncertain
other non icu issues
car constantly blows out hot air. with speed selector In the off position.
- the hot cold dial doesnt work
- also both selector sliders arent functional
- the blower speed selector is functional
the selector and panel for dials illuminate a/c button does not illuminate
the low fuel light doesnt illuminate when low
neither does the brake fluid light
dome light switches on door jambs intermittently operate also.
thanks for any and all help in advance
