How do our fenders remove.
Anyone have a step by step.?
THanks
THanks
http://www.imagestation.com/album/?id=4291072159
tools you need, screw driver phillips, and flathead for prying. 10mm open end, and socket with extension, another person to help.
pic number 26 & 27 show the bolts that are right behind the door. one more at the bottom bottom. you need to have the door fully extended, and then you have to have someone hold it, and pull more, so it goes out even more. it’s a b!tch to get to. and the top is ez. you need to remove your corner lights, if you have jdm’s, then you need to remove the whole assembly, so u can get to a few bolts. there are about 2 i think that are where the corner of the lights are. then there are 3 on top lining where the hood is. i think you need to remove your bumper also. after, you can pry the fender off. the plastic base thing, with the plastic screw suck. some dont like comming out, then i just got mad, then ripped em out. the guard thing stays well though.
it’s alotta work
just go through the album, then there are pics everywhere, randomly throughout it that are helpful.
and while i was at it, i moved the release cable for the hood also. ![]()
pictures 55 - 57 or so show where the location of the bolts are.
