so i installed the b16 todays with new innovation mounts. it was a very smooth swap and everything went to plan. now i want to do a tune up. i got the plugs, ngk wires but when i went to order the cap and rotor threw honda there is 2 part numbers for the del vtec cap. does anyone know what cap i need to order??
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
