Ok i’ve been reading through alot of stuff about my problems and i’m just gonna ask again to make sure i get clear answers to see if i can diagnose it all.
Drivers side seatbelt stuck in down position.
checked the fuses, and was going to just manually crank it back and leave it, got lucky that the tool kit was still in the trunk however it doesn’t actually fit into the crank lol. checked the track doesn’t seem to be stuck on anything.
windshield fuse keeps blowing when i use the rear washer.
it was working fine then the fluid froze, i thawed and drained it put cold weather fluid in, and now if i use my rear washer it pops the fuse instantly.
rear defrost only works on the very outside line, assuming this means bad connections and replace window?(haven’t looked this up yet)
4.Cluster lights/heater control
this one i’ve seen alot about just haven’t tested it yet my problem seems a bit odd. my cluster lights up but the needles don’t seem to be illuminated this is my first G2 so idk if thats normal, the heater control doesn’t light up at all except for a couple position lights if i hold them in when selecting where i want the air coming from. ashtray and lighter work fine, as do the on/off indicators for fog/hazard/cruise however the buttons them selves do not light up.
Cruise control
was working one day but not the next, couldn’t find a fuse for it and haven’t really searched that one.
its late so i don’t think there are anymore lol
any help or suggestions will be helpful, im thinking i need a new module for my seatbelt, and the local acura dealer said its 99.99 to diagnose my seat belt and if its covered by warranty i don’t have to pay but if its not then i gotta pay the fee and then what ever it costs to fix it so thats a fun gamble.
Did you check to see if the belt itself was locked? This has happened to me a few times. Can you hear the motor run?
I believe there is a teg tip to repair this I might be wrong though
Cluster lights the needles really don’t like up there are two bulbs up top that might be burnt out and then there are 3 I beleieve on the back of the cluster might be burnt out. The heaters lights are probably broken solder contacts inside the unit you can pull it apart and resolder the connections and it should fix it.
Cruise control
There is a fuse either under the hood or drivers kick panel I don’t remember which. Does your cruise light on the button illuminate?
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
