ok, im new to g2ic i have a ls in a crx, ok i have a problem im not getting fire, its power before the coil but not after, no codes on computer i fix the other ones, lol, anyways i put the distributor back to stock with a new ignitor. i dont know what else to check im lost i was thinking of the condencer thing on the outside of the distributor i dont know help:bawl:
Did you replace the coil? 94
yes and igniter
You have a new coil.
You have a new ICM, [igniter]
You have 12V+ on black/yellow, [power before coil].
Have you checked the timing?
Have you checked all the connections to the coil/ICM.
If so…
That leaves the CYP/TDC/CKP sensor or wiring from the ECU as the problem, or possibly the ECU itself. 94
