Firewall question.
Is there an access through-hole for the passenger side? Or is there just one which is nearest to the driver side?
I’m upgrading to a bigger wire for my sound system. Need to connect to the battery.
I used the passenger side grommet. I was able to get 4 runs of 1/0 gauge for my battery bank for my system.
Is that easier to get to other than the one at the drivers side?
I’ve done a couple different setups with audio installs and running large gauge wire through the hole on the passenger side, but mine involved having the battery in the trunk, so the wire was actually supplying power to battery, starter, fuse box…
One option is to upgrade all of your starting/charging wires under the engine bay, so that means everything between the battery, starter, fuse box, and alternator. Then you can run your audio system power wire through the firewall and connect it directly to the top of the alternator. This way you don’t have to route the wire through the bay and over to your battery, or worry about having your positive terminal have extra connections. Obviously that setup may not be idea for you, but I’ve done similar setups a few times and find it can often be the cleanest way to get everything wired.
So are you saying I can hook up the a power wire directly to the alternator instead of the battery?
If so, I didn’t know about that. interesting.
Yes, you can. Really once the car is running it is the alternator which is supplying all of the power anyway, and obviously this does not change the requirement for using a fuse or circuit breaker. When it comes down to it you can be quite creative with starting/charging/power wiring.
