FITV Cleaning How To...all links broken
Does anyone have one? all that i’ve come across are ‘Error 404’d’
Google, yo… First result has a full walkthrough with pictures.
http://honda-tech.com/showthread.php?t=1564019
i mean, like is the location the same spot as with that gsr IM?
All B-Series FIT Valves are on the bottom side of the throttle body.
The Idle Air Control Valve is on the back of the intake manifold, and that also should be cleaned out if you’re having idle issues. Again, Google will pull up how-to’s on how to clean it.
