On my teg i have a big dent on the roof. I was wondering if there was any way i would be able to fix it or even if a body shop would be able to fix it. i really want to get it fixed cause its really annoying cause i can be going down the freeway at about 80mph and with the windows rolled down the dent starts to go up and down cause you can push it up from the inside of the car and it gets annoying after a while lol.
you can fix it but if you have no experience in autobody i dont recommend it. all that has to be done is grind the paint down to bare metal, use a stud gun or somthin of the sort to pull the dent out as much as possible then use bondo to fill the dent till its straight
also look up dent pro or a comparable paintless dent repair business.they may be able to fix it.
ok kool i so i guess its fixable. i already looked at the dent king and the dents a little to big for it lol. ok thanks for the info i think i will let an autobody shop work on it lol.
