[SIZE=“3”]All prices are final…Buyer pays for shipping expense(If needed) and PayPal fees.[/SIZE]
[SIZE=“3”]B18C1 Cylinder head(P72)…Stamped as 93 and could have been used in a US 1994 GS-R or 1993 in Japan. Perfect for LS-VTEC as it already has the dowel pins for an LS-block and plug for oil passage. Comes with JDM GS-R Cams and intake manifold. $350.00[/SIZE]
[SIZE=“3”]Exedy Stage2 racing Clutch kit. No heat marks. Ideal for street/track car. Has a little stiffer pedal in comparison to stock. Comes with clutch alignment tool, new throw out bearing, and new pilot bearing. Clutch kit will be packed with instructions, manufacture (Exedy)sticker in its origanl box. $SOLD!![/SIZE]
Rare Integra XSi OBD1 PR3 ECU, and clear Bumper lights.
XSi OBD1 ECU…6000PRM VTEC engagement. $ SOLD
Clear Bumper Lights. $ SOLD!!
[SIZE=“3”]B16a2 (Second Gen)Intake manifold. Fits the PR3 head…not too sure about the LS head, but I think it should fit. Will NOT fit the P-72 head. $40.00[/SIZE]
[SIZE=“3”]DA spoiler taken off my 93 Integra…Grenada Black pearl. $20.00[/SIZE]
[SIZE=“3”]HP Racing header…4-2-1 Design. Does fit both LS and VTEC engines. Designed to make midrange power. $ SOLD!![/SIZE]
[SIZE=“3”]Oil pan taken off a B16…Should also fit B18. $20.00[/SIZE]
[SIZE=“3”]Radiator taken from my 93 Integra. Should fit 90-93 Tegs. Instead of the stock single core, this is a full size Dual core radiator. NEVER had a problem with this unit in the Florida summer heat. Radiator IS compatible with both automatic and manual transmission cars. $40.00[/SIZE]
[SIZE=“3”]B16 Cams with cam gears. $SOLD!![/SIZE]
[SIZE=“3”]JDM B18C1 Cams $100.00[/SIZE]
[SIZE=“3”]PR4 OBDII ECU $40.00[/SIZE]
[SIZE=“3”] Brand new Fel-Pro Head gasket $50.00[/SIZE]
Multi layer steel head gasket that I bought to do an LS-VTEC conversion.
[SIZE=“3”]Optional leather steering wheel. $25.00[/SIZE]
Optional leather steering wheel taken off my 93 GS. Has a rip at the 12 O’clock position. Has normal wear and tear. Could be unwrapped, rewrapped, or just use as is.
[SIZE=3]This is a NEW slim fan for a Radiator or AC condenser. Came with my half size radiator, but never used it. $20.00[/SIZE]
