Flashers wont work
My flashers arent working. It might be the fuse but what else could it be? The relay or something.
replace the flasher. It is the big silver thing in the fuse box. It is a resistor that heats up and lets the voltage pass in pulses to your turn signals.
If you mean you hazards are not working, and if you have an automatic transmission, the fuse for the hazards in at the battery. Mine was all corroded, and I neded to replace the fuse holder and connection to the battery.
James
Does your door chime still beep while the key is in?
If your chime isn’t working and the flashers dead as well, it could be the 15 fuse that’s located under the hood right where the passenger shock tower is…
