One of my bulb fused so i got another fog bulb from another Teg when i went to junkyard. So now i have 2 different but similar fog bulbs.
The problem is everytime i turn it on, it burns the fuse, i replaced it 5 times it blows the moment i turn on the fogs. and that too with 15amp fuses that come with toolbox set.
Is this possible because of 2 different bulbs? or short somewhere?
i’d suspect a shorted bulb. since an H3 is about $5 either online (jcwhitney.com) or at your local pep boys/autozone/etc, go buy a matched pair of H3-35W bulbs and you’ll probably be fine.
both fogs light up for 1 seccond and then fuse blows
The bulb is slightly different for sure, because it has different colour tone, but, its from another integra, so wattage should be same or similar atleast
