I know, there are a bunch of foglight threads out there, but i need a post a little fresher…
anyway, both fogs burned out, fuse constantly blows at the throw of the switch, good ground on fogs, no power leading up to bulb connector, relay (status unknown) location UNKNOWN. fog switch is good, connectors and wires leading back to harness good.
so im thinking a bad relay, or a short to ground somewhere around the firewall.?
Has anyone run into this problem? (ebay 1 pc. headlights) fogs short out. no visible short to ground outside of harness, no pinched wires outside of harness, clean connections.
