Hey everyone. I’m looking to spray tint my foglights and I was just curious as to which was best, spraying the inside of the housing or outside. I had just assumed inside, but recently saw someone spray their corner lights on the outside. Also, does anyone have an info on what paint to use? I’ve been told to use a Krylon Stained glass paint but I can’t find a single place that carries it here in Vancouver. I’ve phoned all over the place but no luck. Cheers.
VHT Nite Shades comes in diff colours from what I’ve seen, testors and VANS also have yellow etc… And I’d do the outside as it’s easier… Just wet sand the fog first, 400 grit wet, 800, 1000, I’d even consider 1400-1500 if you want them to be beautiful…
Then buff the light after you paint it, a day after you painted … let everything cure fully. A powerball and some plastic polish works great
