Fog Light wiring issue maybe?
So, when I got my DA I’m pretty sure both fogs worked. My passenger side went out not too long ago. We replaced the bulb but it still didn’t work… Would this be a short in the wiring? Thanks for help
Have you checked your fuse for them?
yes the fuse is fine
i replaced mine twice and stopped and figured water/moisture was getting in there and shorting them out so i havent touched it, i’m waiting for my one pieces to come in then ill put some back in
check for power and ground. you can use a test light for this.
