Hey guys, I need to know which wires are the ones I need to cut and redo for the fog light mod? I would like to do it the simple way and run the hot to the pinout in the fuse box under the dash. But I wanted to make sure doing that over hooking it into the defrost switch will allow the fogs to run without the headlamps on.
You my friend are a life saver! I had come across that a long time ago but couldn’t fing it again! Thanks a million.
no problem brotha. post up some pics when you got it done
