FOG lights.....help
Hi,
My question is: You all know that you can’t have only fog lights running on our integras. Well, I have seen a couple of tegs with running FOG lights ONLY. How do they do that? Thanks
check teg tips… o course u can have only fogs running… we got our speciality from the teg tippers
this should work! you know when you first click you light swith to the first click, you will see the corner lights come on, all you do is wire it onto those! the second click will light up the front lights so if you want to drive with fogs, wire it to the first click (corner lights), and click it to the first click, and drive! laterz…
but then you would never be able to have fogs turned off (driving at nite)…
o… ::sigh:: people need to use the fQQkin search option more. i know it is illegal to have fogs on only, when there’s no fog, but who gives a fQQk? did u know riding a bike with no hands is illegal? there are too many dam laws, i just dont give a fQQk n e more.
also, fog lights, the tip describes how to hook the power from the fog light together with the acc power from the defroster switch. so you can have them on whenever the hell ya want. fogs on alone, fogs on with daytime driving lights. fogs with all lights, fogs with emergency lights. you can have them on whenever you want, as long as the keys are in and set in acc (the slot before the space where the key returns to when you start your car is actually on)
if you need more explination on how to rewire it, use search, then look for “fog light rewiring” as subject or “tegboi” as user name
