Fog Lights on One Pieces
I have installed my jdm one pieces I just got and my foglights won’t come on. Which connector is for the fog lights, and is there any wiring cutting needed. I have the headlamp jumper harness from password jdm, which is perfect fot the main headlight, but not sure why my fog lights wont turn on. Any help?
http://www.g2ic.com/tegtips/lighting/6.html
http://www.g2ic.com/forums/showthread.php?t=92984&highlight=wiring+jdm+pieces
http://www.g2ic.com/forums/showthread.php?t=159292&highlight=wiring+jdm+pieces
thanks mang. I’ve tried searching…
can anyone show me a step by step with pics, i’m really stuck
ok hope this helps as i just did mine as well. when you took out the old head light the should have been the plug for the head then one for the fog light. the one for the fog light is a 2 wire plug with 1 black wire and 1 red wire. when you install the new one peices the plug in for the fog light is right next to the head plug in . however the usa plugs and the jap plugs will not work together. so what you have to do is cut the old one off thats in the car now and splice on the one that came with the head light. when you got the lights there should have been a male conector that came with it for the fogs. so just splice the new one to your harness then your good to go and they should work. ive had the time to work on it slowly and i just soiderd the wires together then loomed it for a factory look. i had the jumper harnees for the head light to , i just cut the end off and did the same thing. agian hope this helps
hey thanks bro. that’s a clear answer for me.
