Whenever I drive over a bump at any speed, the front right tire of my car shakes violently. I have no idea what the problem is. I have taken my car to an alignment shop and they told me my car needs a new cross member bar because it is bent causing my FR tire to have negatiive camber. Also I need a new FR wheel bearing. I have never had any car shake because of a bad wheel bearing so it makes me wonder what other problems could be causing this.
u came to the right fourm… it has to do with your suspension alright… maybe some of the nerds on here can help you with it… theres alot of possibility that can cause wheel virbation…
bump
Have you checked your struts.:think:
sounds like worn shocks/struts to me. i have the same problem.
