Si I just tore apart a transmission I had laying around and I’m counting the teeth on the gears to get the ratios and none of the online stuff is matching. I plan on emailing Synchrotech here shortly but was thinking I could look to my friends at G2IC for some help since we are a group of cable trans nuts.
Here is the gear set I’ve come up with . . .
Main Shaft
1st ~12
2nd ~19
3rd ~24(according to synchrotech this means it’s B16)
4th ~29
5th ~32
I also did the final driv which came back as 4.4 so that along with the third gear tooth count I would love to think this is a B16 trans but just want to cover all bases. Thanks for any help or point in the right direction.
I believe you counted an additional tooth on the 1st gear Counter-Shaft… 38 / 12 = 3.166 (Y1 Trans)…
No real clue about your 5th gear dilemma…
But I myself have a JDM Y1 transmission… all of the gear-ratios match, but I have a 4.4 Final Drive. Dunno if it came that way or of someone installed it but, its there.
[QUOTE=unified112;2248985]I believe you counted an additional tooth on the 1st gear Counter-Shaft… 38 / 12 = 3.166 (Y1 Trans)…
But I myself have a JDM Y1 transmission… all of the gear-ratios match, but I have a 4.4 Final Drive. Dunno if it came that way or of someone installed it but, its there.[/QUOTE]
i thought the same but i’ve counted em like 10 times lol but thank you for the solution to the final drive issue
