front and rear bushing issue help!
car 90 integra LS
i bought a front and rear swaybar bushing but both are small specially the rear. front are short for about 2mm but i put it anyway, for the rear cant fit at all sway bar way bigger than bushing!
what size bushing do i need?
90 integra LS
ordered oem part #:
51316-SK7-900-Acura BUSH, FR. STABILIZER (23MM)
52315-SK7-010-Acura BUSH, RR. STABILIZER
somebody has to know
I’m not sure what it is you are asking for.
You seem to know the part number… Do you have the correct part number for the correct placement?
Even if you had the size you were looking for, what would you do with that discovered information?
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=INTEGRA&catcgry2=1993&catcgry3=3DR+GS-R&catcgry4=5MT&catcgry5=REAR%2BLOWER%2BARM&ListAll=All&vinsrch=yes
dont know it will help but I have a 93 gs and I just ordered the front and rear sway bar mount bushings with the front being a 23mm and the rear being a 15mm. They havent come in yet so I cant tell you if those are the correct sizes. Here are a couple of links that I found and they might help you.
http://www.honda-tech.com/showthread.php?t=1894834
http://www.honda-tech.com/showthread.php?t=2802579
