Front bumper fitment
I have 1990 da and was wondering if anyone else has had my problem. My front bumper fit isn’t nice and clean. Both driver side and passenger side have a gap between the bumper and fenders. Is there any way to fix this? I had my old bumper and it was the same so I bought one off here that was in better condition thinking it would fix the problem
Are you sure you have the 2 scews that go on the back side of the bumper by the wheel well?
i had the same problem there is a blk plastik bracket on the side of the fender where the bumper gets screwed pop them out and change the white lil squares that are inside the plastik that should fix the problem it worked for me they tend to give out
I’m confused with what the poster above meant. So there are 2 screws on each side of the fender sides. The bumper screws on the white plastic thing that you can slide off. What do you mean I need to change it?
this is the only pic i could find, but he’s talking about the white part on the fender. theres a black bracket behind that white bracket with 2 screws.
make sure that complete bracket is tight and doesnt have play.
yeah on the pic u can see the white plastic par slide it off remove the two screws and the pop the black plastik of the fender and inside there is the blk plastik bracket there is two white square plastik pieces where the screws go in those lil white square tend to give out causing your bumper to hang
what year is the bumper?
