The bumper to my 93 integra seems to be pushed in and sometimes my hood just pops up out of nowhere. The alignment on the lights arent perfect and i don’t know why this is like that. :down:
Any suggestions on what i could do to fix it?
ey u brougth that car from that one guy in milwaukee, huh?
but for ur bumper you can try and take it off and realign everything up… taking off the bumper is easy, just take off both bumper lights there should be two 12mm bolts on each side and the two screws that bolts onto the fender, should come right off with a little push, careful to its kinda heavy… then for the headlights just loosen all the bolts and realign them… also check for frame damage just incase… hopes that helps…
Actually I bought the car from a guy in Sheboygan. I think the guy in Milwaukee sold it to him.
I posted my problem on ht and somebody said they had the same problem, and their radiator support was bent in. If that’s the problem with my car, what would you guys suggest doing?
Thanks in advance
Try pounding the radiator support out or getting a new one cuz the hood popping up out of nowhere is NO JOKE!
When I got into an accident ways back and my hood latch was somehow loose an when I was on the freeway, I guess I was going too fast and air got underneath the hood and lift it completely upwards and and my hood bent all the way back and slammed into my windshield and the top of the hood cracking both my wondshield and sunroof! So get thatshit fixed ASAP dude…
I have the same problem but without the hood poping open.
First thing make sure your latch is working, if it is working but not catching all the way what you can do is take off you latch and put some washers behind the 2 screws try with one washer and if still doesnt catch put 2, if it still not catching get a dent pully and pull the rad support out a little at a time till it catches good luck.
i dont think the hood latch is his problem… his hood lines up prty good with the fenders…rad support is probably screwed up.
I would pull the bumper off and check for damages like stealth da9 said.
or
get one piece headlights. it’ll look better than those uneven usdm lights.
I plan on getting some one pieces as soon as i can find some for a decent price that isn’t too banged up.
Thanks for all the advice, ill go home after school and try to fix it. Then ill let you guys know how it went
