front chamber issues
ok i have newspeed yellow race springs and i have skunk pro upper arms and its still not enough correction what are my options please help i would like to keep the springs
What do you mean not enough correction? What are your current measurements including your cross camber, caster and SAI if you have them? If I remember correctly the camber should be about 1.8 to 2 degrees negative unless your settin it up to specs other than stock.
My previous Integra I had skunk2 arms. It also didn’t give me enough positive camber to fix my issue. My alignment was sitting around -4.0 left and right. My second Integra I went with ingalls extreme and it brought my camber to roughly -2.5 all around. It also depends on how low you are.
