Front End Work
This weekend I am throwing in two drive shafts and i was wondering since i will be under the front and have it torn apart if there is anything else I should replace or do???
I have new shocks and spring but that is it. Is a camber kit something that would be easier at this time? Any help would be great
it is a better idea to get the camber kit installed professionally- trust me
re: install
Why do you recommend a professional install?
Any recommendations on camber kits to buy? I am going to use the washer trick in the rear. But the front I have no clue what to get. My car has H&R Sports 2"drop and Tokico Blues.
You can install the camber kits yourself, you will need an alignment after that though.
I use Progress.
I heard when you install the camber kit that your alignment is so bad you cant even drive, but thats just what heard.
