Front Lip OEM Hardware
Does anyone know where I can buy them? Or at least the part number for them? Thanks in advance
I believe Inlinefour sells a complete kit
They are 10mm bolts, if you have extra interior gold bolts use them
Here’s the part that you screw the bolt into
http://www.hondapartsunlimited.com/acura/nut-air-spoiler-clip/90305-sh3-000-acura/
you can get all that shit at ace hardware…trust me
or your local wrecking yard, heck you might even walk out with a $10 lip you took the bolts from.
There are 30 G2s at PicknPulls within 50 miles or less of you… http://www.picknpull.com/check_inventory.aspx?Address=94401&Lat=37.575887&Lng=-122.327758&Make=Acura&Model=Integra&Distance=50 I got all the clips/screws/blots/inserts for both the front and rear clips, [bumpers] of my 94 Teg at to one PicknPull up here in Kelowna B.C. along with a lot of other parts I needed, or may need later on, like rear side windows, PGM-FI Main Relays, alt., starters, ICU, ICMs and a bucket full of nuts/bolts/screws/clips/relays and a long list of other chit. 94
