I was under my car the other day and noticed that there was a small crack in my front motor mount. It is the mount behind the radiator. Basically I just wanted toknow if anyone knew what the going rate for one of these is. Also most listings I’ve seen have a front, front left, and front right mount. I want to make sure I get the right one.
Originally posted by 93Teg44444
[B]I was under my car the other day and noticed that there was a small crack in my front motor mount. It is the mount behind the radiator. Basically I just wanted toknow if anyone knew what the going rate for one of these is. Also most listings I’ve seen have a front, front left, and front right mount. I want to make sure I get the right one.
Thanks. [/B]
just ask for the “front engine mount” at the dealer or like u said, the one behind the radiator . usually the others are listed as the passenger side front or drivers side front
I replaced mine last year after noticing the inner rubber floating part was not connected.
Had to get this particular mount from the dealer at about $50. I think you can buy OEM mounts for both sides but the front wasn’t available OEM when I searched carparts.com , partsamerica.com and autozone.com
