come to a stop sign and the front right of the car clunks, start to go, same thing. i have a torn cv boot on that same side for about 3 weeks now. could that be it losing oil? i had major suspension work redone about 3 months ago, but i havnet heard or felt the clunk since a week and a half ago. there is no other visual damage. -Dan ![]()
Maybe the CV joint going bad. But it could also be a bad balljoint or tie rod end. Get it checked.
front suspension clunk, explain
I have the same problem but my clunk is more of a clap. This is coming from my brakes though. You can test this by going in reverse then applying the brake again. If it claps, it’s the brake. I doubt that’s that prob though if it’s a clunk.
Might be the radius rod bushings?
im pretty sure its the CV now. its been getting severly worse and now i can hear more than just the clunking, there is more cluttered noise coming from that area. haha wd40 wont help this. thanks guys. -Dan
yep, sounds like your CV is screwed.
later
secret
