Front sway bar help.
I’m missing one sway bar bushing on the front passenger side.
Do I need to remove the whole sway bar to change the bushing?
Can I just remove the bracket, insert new bushing and bolt back up.
Thanks for the help!
You don’t have to remove the entire bar. Just remove the bracket. The new bushing is cut on one side so it can slide over the bar into place. Be sure to put down an even layer of grease. Might as well change both bushings since you’ll be down there, they are cheap.
I recommend doing what I did. Remove the sway bar, clean it up then paint it. I used Energy Suspension poly bushings + end links and it was not expensive. It was like $30 or $40. But then again I tend to be detail oriented.
Thanks, I’ll be replacing it this weekend.
Theres 2 bushings sort of in the middle, and then stacks of them at the ends called endlink bushings. It might be time to just replace all of them.
that is true. thats what i did w mine. but i replaced bar too.
What kind of bar did you replace with?
I was wondering what kind of front sway bar you used…Can you use an ITR front sway bar on a DA?
i went from stock to s tech w energy bushings and end links. i like the feel. jus holding the two bars u can tell the difference.
